1996 K1500 Suburban. My front axle is the 36.5" Dana 60. I want to use ORD brand SAS brackets, zero rates, and crossover steering. I want to use 8" lift 47" springs.
My noobie questions:
1. Using the 8" springs with a zero rate, what are the chances of having leaf spring to drag link interference?
2. Are the centering pins that come with the zero rate a universal size? Like is the diameter the same for all springs? Is the head that goes into the spring perch the same on all axles? Are the included centering pins application specific?
