Stomis
Professional Amateur
Ah ok so I've read on this a little and it seems to cause terrible axle wrap. Are there any solutions for that?
1/4 elliptic suspensions really do need links to locate the axle, the "half leaf spring" is generally only there to hold the weight of the truck.
As for a 3/4 elliptic, it will be squirrelly too without links or a panhard bar. And as mentioned, axle wrap will probably be a significant issue.
When I linked the rear of my truck I initially thought about using a 1/4 elliptic spring and then decided on (free) coil springs instead.
You don't need to do anything as crazy as "elliptic suspensions" to get good flex.
This was my truck a while back, 52's front and rear (the rear was using the stock shackle setup).
You can get all the flex you need from leaf springs. The only downfall to leaves are clearance and axle wrap. You can bandaid the axle wrap problem with an anti-wrap bar.
Links are the best but they require more time and a bit more money.
IMO, 3/4 elliptic suspensions like this are gimmicky ways to get more articulation. They look unstable and probably don't serve much real purpose on the trail (let alone how they probably perform on the street).
