Say what you want about Ryobi
TreeFarm
Internet fabricator.
Anchorage
This damn thing has had a hard life for the last 7 years in my garage.
Yesterday it fell off my front bumper at 50 MPH and went skidding/rolling down the road. My first thought was "what was that sound?" My second thought was that it was time to go tool shopping. Well Ill be damned if the thing survived just fine. A few more scratches, broken magnet, and one screw broken from ripping the battery out. Some JB weld and it will live on. I found the battery like 40' away from the dill.
I have a Ryobi saws-all my older brother gave me probably 20 years ago--the "foot" that you press against what your cutting got smashed and pieces or tha die cast housing that attaches too,busted off when a blade snagged on a hunk of channel iron he was cutting..
It still cut fine,it was just now it had to be held still by hand so it wouldn't just make the saw body go in and out if the blade snagged..
You could see the ring gear inside where the case chunk broke off--I took it apart,wiped out all the grease,which was loaded with metal filings from the blade,it chucked them right in there..
I noticed the ring gear has at least two chipped teeth,but I never heard any noises,nor does it "skip" like they are stripped...
I used J-B Weld putty to seal off the area where the nose cone was busted,let it dry good,then re-packed the gears with disc brake wheel bearing grease...I put a different longer cord on it while it was apart to,with better insulation ,came off a commercial vacuum cleaner..
I have cut countless pallets up for firewood,a K10 frame I scrapped (that I never should have,now I could use it!)--plus a flat bed's channel iron I made for one of my previous trucks--my brother cut all the channels and diamond plate to make a beaver tail ramp truck out of an E-350 box van with it,and I used it on every project on the garage when it needed siding repaired,the house's bathroom floor ,etc.....it has amazed me its still going,and seems no worse than when I got it...if it craps out the next time I use it,it owes me nothing..
If and when it fails my next one will either be a Harbor Freight cheapie or another Ryobi from the flea market,where I see many just like mine going for about $10..I am not going to be up to doing much handyman stuff in the future,so I'm not going to buy anything great I'll rarely use....cordless ones are nice,except for batteries--I'd be killing batteries letting them sit unused too long between charges..they are expensive too..
I haven't yet found another brand that was worth the extra $$$ over Ryobi. Any of the Ryobi stuff I've used has held up as good if not better than the Milwaukee and DeWalt chit I've used.
Fun fact. Ryobi and Milwaukee are owned by and made by the same company(TTI). None of the name brand tools are actually themselves anymore. Really its buying a battery platform that you can live with.
I agree with you though. from a quality for price point of view Ryobi is where its at for me. This drill was like $40 years ago and its still moving along just fine. That battery cost me $40 while an equivalent Milwaukee today cost $150, granted I bought this stuff on sale. I will say that dewalt and the others feel better in the hand. I haven't used any of the newer Ryobi stuff though since mine just works. I have a 1/4", 1/2" impact, 90* drill, and this drill.
There are some things that just have to be high end, places where precision matters like wrenches. for stuff like this, I will buy cheap and if I break it ill buy better.
I’ve had Ryobi and been very happy with them.
I have both Ryobi and Dewalt battery’s sitting on a shelf that won’t charge .
Never saw a reason to spend the extra money for the Dewalt after having both.
I bought some Dewalt stuff after they started to produce limited items in the USA again. I really like them but I also like all of my ryobi stuff. My Ryobi Sawzall has no business still working with the hell I have put it through but it still works like a champ.
x2 on Ryobi drills. I had smoke coming out of mine again this weekend. That just means it's time to put gloves on. Was doing 1.25" holes with a step bit.
