Sbc 350
70jimmy
3/4 ton status
Staff member
Moderator
Released from Pueblo, told I belong in Southpark
350 out of ???? It is 4 bolt main, bored .040 over (not by me). Flattop pistons, New Comp Cams extreme 4x4 cam 12-231-2, lift .432 intake, .453 exhaust, adv. duration 250 intake, 258 exhaust, new comp cams valve springs 981-16, heads are redone with screw in studs, seats and seals replaced, new valves, new hydraulic lifters.
I have HEI dizzy with accel supercoil (used), Performer intake and Edelbrock 1406 carb (both used),
Right now heads are in plastic, they haven't been run since returning from shop. Intake, manny, and dizzy are all out so inspection is easy.
Located in Cedaredge CO 40 miles from Grand Junction.
Asking $1000.00 or $850 without carb and manny. Reply here or [email protected] or 970-261-0349 Thanks
I went with a TBI motor instead of carb.
If you had the casting numbers , we could figure out what it came out of . I already figured its a 357 ( 356.8 ) , so its a good motor for a guy with a Magnum :thumb:
with the .040 overbore and crappy stock rebuild head gasket , its 8.7 to 1 compression with smog heads , a little over 9 to 1 with better heads , a shim gasket would be better when assembled :thumb:
