MechroMenace
Registered Member
To start with my truck is eating coolant slowly but surely and its also quite fat and slow, so my idea for a solution is the sbc 400 sitting to the side of my friends house is mostly complete its missing the crankshaft because it ended up with a rod knock so they took the crankshaft out and it went to a machine shop never to be seen again. they said they sell it to me for 200$ which doesn't seem to bad for a relatively complete motor. But I'm planning on getting another stock crankshaft and I'll be doing a light rebuild on it, I'll get one of those rering kits and freshen it up a bit.
From what I understand thats involved on the swap, I'll have to get a new flywheel because I guess the weight isn't large enough the one in my 89 350. as for the intake it has a carb intake on it so I think I can get a adapter for it and it should be good, but at the same time from what I understand is that the carb and tbi intake are pretty much the same minus the fact that the center bolts are on different angles so I should be able to with a little drill work be able to reuse my tbi intake right? also from what I understand all my accessories should move over no problem either, there may be one or 2 bolt holes that i'll need to drill and tap. other than that everything thing else should bolt on just like it was its original home.
the other thing i'll need to do is possibly the ultimate tbi mods for a little more air flow and an adjustable fuel pressure regulator, and I also need to modify the computer to accept burnt chips so I can tune it a little bit. I've got the moates APU1 so I shouldn't have too much trouble finding or making something that will run it smoothly.
The engine will be going in front of a sm465 with a 205 transfer case and behind that is a couple of 10 bolts axles. so I'm not trying to get a ton of power out of it but I'd like it to be able to get out of its own way and out run a bicyclist. So what are your guys thoughts on this? am I on the right track or is there anything that i'm overlooking?
