The motor that is in my race car that has yet to blow up I bought as a core on E-bay for $90. Put new bearings in it same size as old ones. New cam and lifters. New rings and a set of high compression heads. total cost about $600 and it runs great, have more into the heads $300 the the rest of the motor. Have more into the clutch then the whole motor. If your motor ran before and had no major problems then you can make it run again with nomimal cost. Rings and bearings and the short block would be fine the hard parts don't wear out unless they wear out ie. blow or sieze. Cross hatch the cylinders and put it back together, new cam and lifters and I would probally get the heads redone or buy a set already done, it would be good to go. Line boring or even boring is a waste unless there was a problem to begin with.
