vandelay industries
1) i am looking for a water pump that is:
a) Aluminum
b) standard flow. i don't want (and don't think i need?) "high-flow;" Everything is pretty much stock, and the stock cooling system is doing a pretty good job.
UNLESS, using a "high-flow" pump does not put any extra pressure/strain on the stock system; In that case, i may consider a high-flow pump, i.e., Edlebrock 8811 etc.
c) High quality; Money is not an object as long as it is under $300.
2) Now, if #1 cannot be achieved, then what is a good quality stock-type iron pump?
a) Aluminum
