If both axles are anchored somehow, it will come right out. Not meaning the truckI need to think this one through. Plenty of suspensions will do a crummy job of transferring force to the frame. But aside from that, what is the downside of using a suspension mount? If your wheels are buried, and you can get a strap securely on the affected axle, it will give a more direct connection between the stuck wheels and the winch. Pulling on the frame would require the suspension to transfer that force to the wheels, and that springiness may not always be desirable.
last year in Pritchett they peeled apart a military wrap spring by pulling on the front bumper when the rear tire got snagged. Could just as easily done similar if the front was anchored and they pulled on the axle.
food for thought
