School me on bolt grades....
Nylock I can see failing, hate those things... but even hardened lock washers, i.e. grade 8 or the like, you see them fail?
-- A
dont like them under heavy loads thay can spit out . hell half of them these days spit out trying to tighten the stuff down. i just go with stoke / metel crimp nuts and never look back. thats the same stuff the factroy used so good for me. :D
and half the hardware that places include these days looks like china crap i toos it and use my own stock reuse stuff or new from local supply house i buy from that gives me killer deals over gen hrdware store prices.
I was in class yesterday, and the instructor was giving a lecture on 'direct replacement' and why you do it....
I had NO idea that a grade-8 bolt had LESS shear strength, but more longitudinal strength... :dunno:
Is this true?
And why>? :popcorn:
The instructor was incorrect. The grade 8 has more shear strength than an equivalent size grade 5 bolt. The shear strength is a percentage of the tensile strength and grade 8's have a higher tensile strength. This is a fairly common misconception and due to a grade 5 bolt typically just bending when it fails where as a grade 8 will typically snap in two, though it will be a much higher load when the grade 8 fails.
Another reason lock washers are bad, at least on suspension parts is that they will rust out (if your in the rust belt) and then there is a space for stuff to wiggle around and cause problems. Steel locknuts for the win,
I think its funny when your in a class put on by Fastenal (who sells them) and they tell you NOT to use split ring lockwashers:haha:. they recomended the crimped steel nut or loctite.
