As a lot of you guys know, I am doing a Trazer swap on my K5 frame. With the cab on the frame and the rear of the frame shortened, I have limited room to work with for fuel storage. Basically, I have roughly a 28"x19" space to use for a fuel tank. I am running TBI, which has a 3/8 feed line and a 5/16 return. What should I be looking for? I have done some research, but I can't find anything that looks like it would work with my current fuel line routing. Also, would I have to run an externally mounted pump or could I use an in-tank one? I like the reliability of the in tank one with it able to run cooler and everything, but I haven't seen anything where I could run an in tank pump with a fuel cell
