Nefarious Cohort
Registered Member
Greetings,
I recently was given a 76 GMC Jimmy, its been rode hard and abused to the point that there are a few broken leafs in one of rear packs and a front shock mount torn away.
After searching and reading many a post here about spring packs and swaps I often see where 52" or 56" springs are mentioned.
What is the significance between the spring sizes and what makes them desirable one over another?
Since I am going to need to replace the rear packs I might as well replace the fronts too (since they were all abused together), I figured I would head to the local wrecking yards looking for a suitable donor vehicle.
Is there a preferred year/make blazer/suburban/PU I should be looking for?
I do appreciate your time and help
