School me on panhard bars
Phil513
Freakin' Sponge
Las Vegas
Just wondering their purpose. I was looking at the TNA engine crossmember (which I'm sure I don't need, so far my stock one does the job). It has an integrated mount for a panhard bar.
Since the bar is mounted solid to the crossmember, and I assume solid to the axle, and it swings down in an arc motion, doesn't it pull the axle off to one side?
And, basically what is it for, and how do you know you need one?
Yes, it does pull the axle side-to-side somewhat when cycling up and down, but the goal is to hold the axle roughly where it is in the left/right axis (it's not a perfect system, just a simple one). This is useful if you are running springs that don't keep the axle centered (like your leafs are currently doing). Throw a trailing arm on each side of the axle and you now have a basic 3-link suspension.
For your rig, you would only want one of these if you were planning to ditch the leaf springs in favor of some other form of suspension. While this could be a fun project, the fact that you are asking the question leads me to believe that you should do some more research before the cutting and grinding begins. :wink1:
I meant to put this in the garage. Dammit.
Ask one of the mods to move it.
@Greg72, @tRustyK5, etc...
Thanks much! No, I have no plans for it. I was curious if it went hand in hand somehow with crossover steering, which I do want to go to eventually. But sounds like that isn't the case.
I really appreciate the answer though! I have looked at that arc and it has bothered me for a long time.
Yeah, there are much more perfect ways of holding the axle in place, the panhard is just one of the simpler ways.
And, yes, it does go with crossover steering, as many of the people doing the one are also doing the other, in addition to lots of other mods. :haha:
If I put in a panhard bar, might as well get a Dana 60. :D
Yes, I will. And I really do want to go Dana 60, I'm saving for it and keeping my eyes out. Already have the 14bff.
No, just if I'm going to change over to 8 lug, I should just do it once and then be done with it. If an 8 lug Dana 44 falls in my lap, I'll run with it though.
