cdoggwsu
So I've noticed while driving at higher than about 35 mph if I let off the gas the front end sounds like it's grinding for a second and then it stops. If I give it a little gas is grinds quickly then goes away. By feathering the gas pedal between accelerating and decelerating it will continue to grind.
I took a look under it a while back and noticed the passenger side tie rod end was scraping on the balancing weights so i figured that was the problem but after having them switched to the stick on type it's still grinding. I checked the top of the caliper and the bracket all around the rotor and there is no sign of scraping so I'm kind of at a loss.
Could this be coming from the front diff? The hubs (manual) are unlocked but is it possible they aren't fully disengaging? Any input is appreciated. Oh, this is the 88 K5 in the sig, open 10b 3.73 front end. The wheels aren't stock and the clearance is pretty tight.
