Seal HELP
4X4HIGH
1 ton status
Fremont, CA.
Does anyone have a JB conversions SYE and have the part number for the output seal? The best I can read the number on the current seal it is an NOK brand seal with a part number of UWO194E and Ii found a website that I was able to cross reference that number to an SKF seal 18687 and every dimension is the same EXCEPT the width of the seal. I'm thinking it is a modified seal.
Thanks but I found a seal that works just fine although it's not a double lip seal like the original one. I did find out that JB conversions has that seal made exclusively for them (so they say).
National seals that start with 47 are non-reinforced double lip seals.
It is the seal that jb conversions told me to use as a replacement.
The 472572 national seal is not the same double lip double spring reinforced seal that comes with the jb sye. It has one spring with 2 lips. It IS a double lip seal. I used it because i couldnt wait a week for one to ride up here from jb. I damaged my original.
It has been on my rig for 8 months and almost 10k miles with zero leakage. I laid eyeballs on it this week.
I have this seal in my hand right this second and it IS NOT a double lip seal. I know there are double lip seals that only have one spring but this is not one of them.
I have the 472572 in my truck and IT IS a double lip seal.
Edit:
Either you have a mis-boxed/labeled seal or you expect something other than what Manufacturers term a double lip seal.
We apparently wont agree on this so i am going to let you continue your search for the elusive ideal seal and I am going to move on to something productive.
I already have my t-case back together and have found a better seal to use than the National 472572 seal so it doesn't matter to me anymore at this point. Also it really doesn't matter if there's a seal or not as the bearing that JB Conversions uses is a double sealed bearing.
