Searching for a specific switch.
GRINCH
Helena, MT
I have been searching the Web for days looking for this switch. Not the guarded rocker but the smaller push button momentary switches. I found some close but not exact. I want the hole diameter to be 1/2" or less.
Anyone???
Ok, that did not work either. So, do this. Go here: http://www.digikey.com/
and do a search for this: CKN9967-ND
They have others be sure to check the spec sheet for this one, because it comes with different buttons.
Also try a search for domed push button switches on that site.
J.
OK, one more and you are on you own. <G>
Search on this:
EG4722-ND
More current handling, cheaper, and better for your use I think.
J.
why not just call 12voltguy? thats who's panels those are..
Ok, Also try a search for domed push button switches on that site. J.
Thanks Fordum. I knew you would respond!!
It would of helped if I searched for the proper term. "Domed". I used digikey before but was looking for the wrong term. It's the simple stuff that gets ya!!
Found what I was looking for and the price is right!!
x2 he can get you just the switches or push buttons
They are the 12Volt guy panels.
I did check his site but he only has the toggle switches listed. I didn't bother calling for a couple of reasons.
1. I'm cheap, frugal, or whatever and didn't want to pay any mark up.
2. I thought it would be tacky. "Dude I don't want to buy your panel, just the switches so I can build my own.
FYI,
In my search for panels and switches I did run across a cool site. You can design your own panel. You download their software, draw up the panel to your specs, like hole sizes, material, color, and text. Then hit the order button. I will post more about them in my build thread.
http://www.frontpanelexpress.com/products/front-panel-designer/how-it-works/index.html
Kind of off topic, but sense you've found what you're looking for I think it's ok, I couldn't remember where I got my switches but maybe it was 12voltguy?:confused:
