Seat belt?
77k5blz
Mchenry illinois
I have a 77 k5 cheyenne and when I bought it the interior was missing a few key pieces. Such as front seats visors and rear seat belts. I only see two bolt holes in the floor behind the rear seat. Does anyone know the stock configuration for one of these. I have the lmc catalog but they only sell 78 and up rear belts, but they do have those old school ones where you buckle it then pull one side tight. I dont even know if its supposed to have two or three passenger belting capability. Please I need some input on this I have a 2 1\2 year old son and he wants to ride I da da's big truck but I cant take him without seatbelts thanks so much. p.s if anyone can put up a pic of a seatbelt setup that would be awesome .
thanks again, Rick.
Thanks buddy thats awesome ill just get the universal lap belts from lmc you dont know how long they are do you?
I meant how long your seatbelts are so I can be sure the lmc ones will work. Thanks again sorry to be a pain but its hard to find trivial info like this.
I'll let u know on Monday , not a problem.
3 person setup, pull type lap in the middle and retracting lap on the side. Ill get a pic of it Monday.
Retractables extend 30 inches from retract housing, they are 7 inches from the mounting bolt hole to the backside of the retract housing and 10 inches from the bolt hole to the front side of the retract housing. Making a grand total of 42 inches extended from mounting bolt hole to end of buckle.
The lap belt for the middle extends 42 inches from the mounting bolt hole to the end of the buckle.
The buckle sections are exactly 16 inches long from the bolt hole to the end of the buckle.
Give or take an inch either way for snaking tape measure thru seatback and angles for the lap belt and retracters.
Hope that helps.
