Anyone have a creative fix for this thing or know where I can get one? I don't know what it's called, but it's the little plastic button on your lower B-pillar seatbelt spool. It sticks out into the doorsill and draws up the slack in the seatbelt when you open the door. Come to find out, it doesn't ratchet like it's supposed to if this button doesn't work. It just thinks the door is open all the time.
It's made of plastic, and as you can see, mine is toast. I thought about sleeving it with some thin tubing, but the plunger doesn't have enough clearance around the OD of the plastic button.
