I have an 81 K5 that I am restoring. I was thinking of buying another seats (front and back). When I see it on ebay I usually just see front or back. Does anybody know of good junkyards that sell online that could have a complete sets?
I have to import from US because there is no way to find it in Iceland. I am hoping there are some companies that I can buy directly from.Most places just sell based on front or rear. Just gonna have to find the year range of seats you want
Or just hit up a junkyard that will still let you out in the yard
Thevjunkysrds around me want a couple hundred up to 1000 for a complete set of seats. But you still need to build a seat bracket to bolt it into your truck once you have them.
I got enough rust issues I don’t want to just start drilling extra holes. And it’s way harder to do that on my 72. It doesn’t sit the same way as a newer blazer. The way the seats are sitting are not the same in every truck. If it worked for you then good. I haven’t tried this yet but I’ve seen others say the stock ones don’t sit right and they had to modify the stock brackets to fit. I’m looking for a set myself to try out.You don’t really need to build brackets for the front seats. You just drill holes for the bolts that don’t line up and add some big washers/plate underneath.
The rear seat brackets are stupid easy to make. I just used angle iron and some steel rod.
