Second Gen 14bolt disc conversion...
scaryfast68
Registered Member
Texas
Hey guys, I've got a '90 chevy 14bolt axle swap goin on and I've been lookin for kits to convert to discs, however I've found through the 14bolt bible, that my axle is a second gen and won't accept discs cuz the hub is not machined flat because the drum slides off. How do I overcome this? Is there a kit that will bolt on and work? or am I gonna have to get a set of hubs off an earlier axle? Thanks guys as always
http://www.blackwidowperformance.com/
shane74 here is one of them. him and i prototyped the kit he now sells for this.
its for the 14ff pop off drums. i never had a issue with just setting my rotors on and banging in the studs. almost 10k miles no problems.
and dont even wast the time for older parts . the spindle spacing is diffrent. wont fit or work. i found out the hard way.
and if stock wheels you will need a spacer to take up the extra lip spacing from the drum not being on there.
