vortec
i made a post about this over at fullsizechevy.com and got what i think is a good answer (supported my worst idea) but i'd like to see what answers this board provide.
the situation: 94 4.3L c1500
engine idles pretty well, but as rpms increase, it feels weaker and starts to stumble. if i open the throttle quickly at all it stumbles and almost dies, regardless of speed or rpms. under normal operation, my air/fuel ratio gauge should swing from lean to rich constantly as the computer adjusts, but it's not making i to the rich side anymore. i checked fuel pressure yesterday. 11psi, which is right in the middle of factory spec. but, i have no residual pressure. turn the key out of "run" and it drops to zero in seconds. i think the fuel is draining into the return line too soon, so enough fuel is goint to the injectors for light use, but it can't handle any extremes, like compensating for cold air (30s) or WOT.
i'd love it to be the pressure regulator, but one of the guys over there suggests the foot valve in the fuel pump, necessitating a pump swap. i'd like some more input before i go drop my tank.
