Mudstud
Playing with options for mounting the ram. I don't have the means to weld to the cast dif and i don't like the idea of welding to the diff cover. I also want to get the ram up as high as possible. I have flipped the ram to where the body mounts near the drivers side C and the rod clevis would be welded to the middle of the tierod. You guys see any potential problems with this set up? I would go with straight up hose fittings at the ram. The only potential problem I see is that if I bend the tierod too far up and back the body of the ram may come into contact with the U bolts. It'd have tio bend a good distance though. The one fitting is close to the leaf spring but it should be enough clearence to not make it an issue. I tacked everything up (after I took the pics) and then realized one problem. With my wheel locks (lock to lock limiter bolts at the knuckles) set at 1" out. With the ram fully extended and tabs tack welded in place when I turn everything (draqlink diconnected) the other direction, ram compresses and bottoms out before the wheel reaches lock- knuckle has about 1/4" - 3/8" left before it hits the stop. I guess I'm gonna have to loose some turning radius and split the difference in the rams throw?
Don't make fun of my white socks and sandles- It's not everyday I dress up like that.
I plan on using some 1/4" angle on the tierod to help distribute the force of the ram and keep the weak factory rod half way straight.
