Yea....was afraid there wasn't an easy method. Gonna soak w oil for a day or twoYes soak in penetrant tap with soft face hammer. Maybe hit with a heat gun.
An impact driver might shock them loose after all of above.
Not an impact gun, air or electric.
Don't have an impact bit that small. Gonna have to grind down a larger one.Yes soak in penetrant tap with soft face hammer. Maybe hit with a heat gun.
More than one way to skin a cat. I found that the hinges for those little windows each had two screws that mounted them to the aluminum extruded frame. Two or three of those screws came out easily but I needed to use a lot of force and Tiny movements to get the other ones out but ultimately they came out without stripping the heads or the threads. This might be the way to go. It seems that those little screws that I was trying to remove are only for tension on the hinge pivot points. Ultimately I'm going to have to remove or loosen those tiny screws because three of the hinges are seized and will only allow about 1/4 inch movement. I have them soaking in PB Blaster right now. I think I might do a separate write-up on taking these apart. I've never seen a post describing this.Yes soak in penetrant tap with soft face hammer. Maybe hit with a heat gun.
May try that for the drivers side.I thought a 50/50 mix of acetone and atf worked better than PB Blaster or anything else on the market.
