thebluemax
Yes I searched,lol. I will hopefully be picking up a 6 lug semi float 14 bolt in a couple of weeks out late model 4x4.Axle will be going into an 84 chevy 1/2 ton 4x4. I have few questions:
Do I need a conversion u joint or can I swap the yoke from a ten bolt?
I will need new u bolts, spring perches,and shock mounts correct?. Does the semi float share the same spring pads,shock mounts, and u bolts?
What do I need to hook up the emergency brake cables?
Anything I missed?
Thank you for your time and any help would be greatly appreciated.
Anything I missed?
