philtodisco96
Newbie
Hey all, just picked up an 87 Blazer last week and it's running pretty good. It had a surging idle (only cold starts), but I cleaned up the IAC and I 'think' it solved the issue. Also found a new o2 sensor in the truck so I changed that out too. Also replaced the fuel filter as the one in there was pretty crusty. Fuel pump is pretty recent too I believe. Anyways, I'm now getting an issue where the truck wants to stall and sometimes does when I'm giving it only a little bit of gas, it's almost like a revving sort of thing. Soon as I back off the idle kicks in and it's usually fine. Just curious if the sensors need to calibrate and reset? I did have the battery unplugged when I did all that work. I've driven it probably 10 miles so far. If not, what do you think I should try next? At higher RPM's the truck feels GREAT, it's just those low, barely pushing the gas pedal RPM's that are bogging out.
