Looks like the wheel studs hold the hub and drum together? Is it kosher to hammer the studs through with a big punch?
Ive never damaged one by using just the hammer straight on the end of the stud but you do have to be careful.
. These can be used with a disc brake conversion or without.You need a pair of these rings so you never have to press out studs again to seperate the rotor from the hub, ust unbolt it. These can be used with a disc brake conversion or without.
http://coloradok5.com/forums/showthread.php?t=135349&highlight=rotor+spacers
Any intrest in these? I may start machining these to sell. Let me know. There has to be enough intrest in them to make it worth my while. But if we get enough intrest in them....Cost will have to be calculated of course.
yes that what you want, but is the "juice worth the squeeze"? you can get a shop to press out the old and press in the new studs for 1/2 the cost of buying your own press. On the other hand do it wtice and the press has paid for itself... just thinking out loud.
Not sure what tools you have at your disposal.... I use a $40 air hammer with pointed punch. Has made life very easy pressing in and out. Just very noisy.
