fwc
Registered Member
Everything was running fine until two weeks ago...
On a "cold" engine it starts fine, idle is a bit rough with some surging. When I first put it into gear the idle drops a couple of hundred RPM and then comes back very rough.
Acceleration from a stop is horrendous, like I have a wheezing four cylinder under the hood. It surges and jumps and then smooths out after 2000 rpm, when the tranny shifts it bogs down again until the RPM builds up.
Running on the highway, it seems pretty good although I can feel a slight miss every once in awhile. Acceleration from speed is fairly smooth although it doesn't always kick down a gear. Once it has all warmed up and run on the highway for a bit, acceleration around town isn't too bad, but still not perfect.
91 Jimmy, stock 350 TBI and auto, only things that haven't been replaced within the last few years are the injectors and fuel pump.
ALDL logs attached. This is from a "cold" start, warmed up for about a minute and then driven a couple of miles. Any thoughts?
