Serp assorries
1979jimmy350
Ann Arbor Mi
I have a complete TPI style serp setup that i am currently running, i will be switching to a 5.3 L so i do not need them anymore. The setup includes both Brackets, Aftermarket Crank and Alt pulley from summit. AC delet pulley, New style Fan, New Serp belt, High Amp alt ( i belive a 95 Amp), Water pump with maby 2000 miles on it. This is a complete ready to bolt on setup, I am asking $250 plus shipping
could you get some pics? could a/c still be used with a different belt? might be interested. thanks
yes ac could be used still all you have to do is put a compressor in place of the delete pulley and make sure you have the correct belt
Here is a picture when i had the setup on my other truck. This is before the pulleys, i don't have any pics of it with the pulleys and this shows an ac compressor that i used until i got the delete pulley. I also forgot that the power steering pump is included and i will warrenty it through autozone so you will get a brand new one
