Serp Question
Russell
3/4 ton status
Rocky View County, AB
Hey guys!
I've got a semi stupid question for all of you:
What direction should my alternator, power steering pump and water pump be rotating?
I think its the alt and power steering pump spinning clockwise, with the water pump spinning counter clockwise (assuming you are facing the front of the engine), correct?
The K25 just got a non-AC serp belt setup, but I have to re-route it due to clearance issues with the TPI throttle body & air ducting. I've got a routing that will work so long as the above info is correct :D
Correct! :)
