Look and see if anybody has the part number diagram to go for serpentine belt setup on my 87 Tbi. I already received the two brackets.The main brackets.. And understand I need to change the power steering pump.And i'm not sure about what pulleys or tensioner are required for this setup.
Thanks in advance for any info You can provide .
Louie d
Louie d
Otherwise most anything from the 90s will work if you aren't worried about the AC position. Reverse rotation pump/clutch/fan like others said.
