TX Serpentine dual altenator bracket
84k5oleyeller
1 ton status
Texas
IMG_2955.JPG Sbc dual altenator serpentine bracket. Bracket came of 4.3 passenger side. Use this bracket with tbi style driver side power steering/altenator bracket to give you dual altenators. I was going to put this on my 383 but decided to go ls. I can sell the single bracket or both brackets.
$20 single bracket $50 for both brackets plus shipping
You will have to change waterpump to change to serpentine from v belt due to water pump being different
To be clear, the pass side double alternator bracket replaces the original serpentine bracket? Or does it attach to the top of the original serpentine bracket?
It replaces the passenger side bracket. So it also replaces a/c pancake compressor and smog pump if you still had them. I would use them on my set up but no longer running sbc.
I was wanting to run a two battery system for winch and accessories.
Ok. I was hoping it would bolt on to the regular bracket, mine are powder coated so I don’t want to get rid of it.
