Serpetine system from '91 Sonoma 4.3 on a '84 K5?
divorced
3/4 ton status
Will the serpetine belt system from a '91 GMC Sonoma with a 4.3 work on a 350 engine from an '84 K5?
My friend is swapping a V8 into his Sonoma, and wants to use his current belt system on a carbed 350, and he can get the 350 from an '84 K5 if it will work.
:confused:
He will need to change the water pump too. The serpentine system will spin the older water pump backwards = No Cooling. Serpentine water pumps are reverse rotation.
Serpentine
If this is true that the 4.6 and sbc 350 are the same? My question is will a serpentine accessorys from a 454 be the same as 4.6?
Dan
Dan
Uhh, 4.6 sounds like a Frrd engine.
The GM 4.3L V6 is basically a 350 V8 with the back two cylinders removed, which is why they have the same bolt pattern for accessories up front.
To actually answer your question I don't know whether the 4.3/350 stuff will cross over to the big block, but you'll have better luck finding if smallblock stuff will move to the BBC. (And I think, from my experience, the answer is no... but I could easily be wrong.)
-- A
