Set of Bilstein 5100 series shocks
Bump. Got someone intersted in the longer ones so if anyone needs the shorter ones i'd be willing to split them up.
Bump. Here are the specs on the shocks if anyone is interested.
Shorter ones are 15.9 collapsed and 25.9 extended
Longer ones are 17.9 collapsed and 29.5 extended
All 4 have 255/70 valving and the whole set could be shipped for under 30 bucks I think.
Bump. If someone pm's me a reasonable offer I might let these go even cheaper. They aren't doing any good sitting in my garage unused.
what lift size do you have on your truck?
Not positive what size i need yet. Stock with 1" zero rates all around, but the 14ff i added in the rear has lower shock mounts.
Hm. I'll check lengths and get back to you.
These shocks were for a truck with a 6 inch lift so probably best to check the lengths and see.
Do you have the boots? How many miles did you put on them?
Nevermind. The fronts are way too long.
If these are still available, I may be interested. Will know more late next week after I measure flex once I put on the lift. ;)
