ciffer
what is the procedure for setting ignition timing on a '72 350? the motor is not originial to the truck, so i don't know whether or not to trust the sticker on the header panel.
the motor is out of a '72 class C motorhome, it is completely stock and has about 25k miles on it. it has the originial vacuum-advance distributor. points are new, i have no reason to suspect any malfunctioning parts, just need to check the timing and make sure it is correct.
