hillbilly deluxe
Professional Pile-It
I am working on installing my ORD shacke flip right now. I know this is going to change the pinion angle quite a bit, but is it also going to cause the axle to be further forward? Since the spring pivots from the front spring hanger it must move forward a bit. I also have some zero rates from ORD so I could move the axle rearward to compensate. I thought about just moving it back anyway but kinda doubt 1.5" is going to improve my departure angle noticeably.
Also, I'm going to do some 52's up front. How do you measure the leaves? I found 3 or 4 different lengths (maybe...) of rear springs on a variety of old chevys while at the junkyard.
Thanks!
Thanks!
