garydan
I did search, but I'm still not sure what if anything I need to do here. Here is a picture of the shackles after the DIY4x flip was installed:
What do you think about this shackle angle? They are pretty much straight up and down! The flip was installed in the stock hole locations.
This is how the truck sits now:
I have another problem, which you can also see from the shackle angles being different. The whole truck leans to one side slightly. The driver side is about 3/4 inch lower than the passenger side. I've done a 1-ton swap, with brand new 6" TC EZ Ride Springs up front. In the back I have old rough country 2" lift springs, the DIY4x shackle flip with 6" shackles. I noticed the tilt before the shackle flip install, so it must either be the rear springs are evenly worn or something with the front setup. Any ideas?
After I tackle this... its on to pinion angle! She looks setup right for a CV axle (pointing straight at the output of the TC), but I don't have a CV Axle yet. Is it worth doing to SYE on a 208?
