Shackle Flip Pics
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
I've been busy doing a million things like normal, but here is one of my on going projects. I've pulled the 1/2 ton axles and have a set of 3/4 tons (D44 front/D60 rear) to go in but at the same time I wanted to remove the 6" blocks from the rear.
Had a small issue pulling the 52" springs and had to break out a sawzall to get one bolt on both springs.
I've scavanged as set or rear spring front hangers and 56" springs to replace the stock setup. I first mocked it up using the 56" springs and the stock shackle, but it didn't look like it would work all that well to match the 6" front springs.
So after ordering a set of longer shackles from Kert at DIY4X I've got a better overall setup. Its shown in the pics at full droop but missing the weight of the axle and tires hanging on it still.
I positioned the bracket by re-using the upper rear rivet hole from the original bracket. Then drilled 3 new holes, all reamed for a tight fit on a 7/16" bolt. Ideally you want the shank of the bolt to be the only thing in the frame and a tight fit with no threads against the frame or bracket hole. Its perfect if you have to tap the bolts in lightly with a hammer.
I won't know the net lift until I finish getting the axles and tires back under the truck and check to see how level it sits with weight on it. But I'll adjust with a zero rate if needed. I should be close to level with this setup.
Are you putting anything like tubing between the bracket and the bottom frame? Something to hold it square?
you can see the factory bracing still riveted to the hanger in the pic he has. Personally I would have cut it off before and welding it in place after bolting it to the frame. Then run a bolt up through the bottom of the brace through the frame to have it fixed in two different stress angles. I would like to use the stock hangers to make a homemade flip this way...BUT, I have a m1008 and havent seen any srw c30/k30s anytime recently to scavenge...:(
Flip looks good BTW, I think if(when) you move the brace, the bracket will be plenty strong enough to take some abuse.:waytogo:
Remington
It is a short box K10. I positioned the bracket by re-using the upper rear rivet hole from the original bracket.
I'm going to pull off the original brace and build a replacement or just put a solid piece of steel in there to fill the gap. I originally left it on because I was going to try and position it using that brace at the bottom of the frame before I realized it was too high that way. Its an odd size to try for tubing (1.75") but it would be perfect for a 2x4 piece of lumber though :haha:
lol yeah I think that fabricator thread should be deleted so you dont get any ideas...lol .
Remington
Threw in my Dana 60 rear axle and test fit one of my spare 37" tires today before Thanksgiving Dinner.
looking good mang, are you planning on doing discs or just working on a brake job on the drums?
Remington
I've already got disc brake brackets from Kert so I'm planning on discs. The drum brake parts on this axle are pretty shot anyway so disc brakes are cheaper at this point.
What length shackle did you get from DIY?
I like the rear shackle angle, its a little much for a DD it seems but that is what Im looking for on my rig.
Where did you obtain the 56" springs?
I have the 7" UDSR shackles from DIY4X. The springs I picked up used from a guy on a local board. This whole setup comes very close to the original ride height of the 6" block.
Little bit... I had to rotate the spring perches 5 degrees to get the correct angle on the ujoints. Forgot to take the camera with me when I had that done though. Here are the pics of where I was at just before rotating the axle and relocating the shock tabs.
Truck looks good! Nice work. Looks pretty straight from the photos.
Is that a pink two wheel cart?:D
The truck looks straight... I've already found one spot of bondo in the bed while unloading tires next to it and I'm sure there is more. When the tire hit the pass side rear behind the wheel well it cracked the bondo. You can see it in the newest pics.
I've got a set of 38's for it. Still plan to take out the body lift though and trim fenders as needed. There is just way too much space between the body and 37's on the back now.
I saw the line on the bedside but i thought maybe it was just a glare from the picture or something. 'd probably be careful if you're already finding bondo whenever you go to cut your fenders out
