a 52 or 56 swap will net 4" of lift from a stock spring.. but that's a bit more involved than throwing in some stock length springs (47) it has some offroad plus's, and on-road minus's..
for stock 47's, you can change shackle length a little bit up there, but it's generally best to keep that modest (1/2" to an inch, netting you 1/2 that height) or you start to run into caster issues affecting steering, etc. you can also get an inch from adding a zero rate, which also allows moving the axle forward...
obviously a block is a no no up front...
my K5 is set up with 4" lifts, HD ORD shackles, a zero rate and 1" body lift to net about 6"s up front.. some fender cutting and 38's.. Mutt will have 6" springs, HD shackles and 37's, no cutting.. maybe a zero rate down the road to bump the axle forward..
