GM4wheeling
So i was reading on ORD about their shackle flip kits. It says that if you were to get bigger springs someday that you can install the brackets that come with there kits "backwards" on the "wrong" side and they will act like the stock shackle brackets.. Now heres my question.. if those brackets can be flipflopped... can you flipflop your stock brackets to act as a shackle lift?
I just want to minimize the hight of my rear blocks to minimize all the negative effects of the block itself. And this seems like a quick way to get 4" so i'd only need a 2" block... you follow? Or... anyone know what a set of 6" lift rear springs run?
yeah yeah yeah... noobe question i bet....
I just want to minimize the hight of my rear blocks to minimize all the negative effects of the block itself. And this seems like a quick way to get 4" so i'd only need a 2" block... you follow? Or... anyone know what a set of 6" lift rear springs run? yeah yeah yeah... noobe question i bet....
Is it worth the money to get the kit... just so that i can downsize my blocks? How bad is it really to run 6" blocks back there? And then... again, are there 6" lift rear springs sold anywhere?
