johnnychimpo
I bought all new front susp. bushings for my '90 Sub. Whats the easiest way to remove the shackle hanger bushings in the frame? Mine are in good shape but I'm putting in greasable bushings for cool points.
I used a flat screw driver and went around sliding it in between the bushing and the mount and kinda broke the seal that was holding it in, then pulled it out.
So there's a sleeve in the shackle hanger too! I fought the rear spring bushings for 3 hrs. Not fun.
Do you mean the sleeve the bolt rides in or is there an outer sleeve between the hanger & the bushing?
