Alan2smiley
I'm in the shop
88 GMC CC On a rough paved road. Is this normal? 52" ORD springs with poly bushing with about 3500 miles on them.
I can only try to go fast and since it's little heavier I start with 200psi. ThanksMost the go fast guys run about 150... Usually people start at 200 and work their way down.
It does seem to flex side to side quite a bit--but who knows if that's "normal",it is only recently we have the ability to watch & record things like this...
If the shackles are longer than stock they will flex more-I am kind of surprised they are not "H" shaped with a tie bar across both plates,that would help keep them from flexing as easily..
Now that I have seen the video it's little sloppy.Does it handle weird at all? Wandering and such?
P.S. Love the sound of that 4bt![]()
I have a idea that should help, will post pictures when it's done.
