Shackles and pinion angle
goochieman83
Tampa, FL
Just out of curiosity, does shackle length affect pinion angle. I am rocking some 6" shackles and would like to drop down to about 2-3" and add a leaf or get new rear springs. I believe I read that longer shackles rotate the nose of the pinion upward.
Correct. If you want to do some trigonometry, you can find the angle difference
Ok, I have the diy4x shackle flip in the rear, what length are stock shackles? If I get new springs I don't want to have it too high/low in the rear.
I would PM Cyberfire (he is DIY4x) here on the board, he can get you the best idea what springs/shackles/lift is going to work with your plan.
