ClevelandCruiser
Registered Member
I just completed my 52/63 spring swap and now i need some shafts. i think im goin to go with the 1350 CV from HAD but i was wondring on how much slip i should have? any suggestions will help.
There are custom slips you can get that are much longer than thati ordered the stuff for a d-shaft yrs ago...iirc they only make a male/female slip for drive shaft up to 12''...this was all spicer parts tho
when i ordered my male/female slip, i cut the d-shaft, measured its diameter, prepared to order parts, thought i had all info, was just getting longest slip they had, i had to call them back...i didn't have the d-shaft tube wall thickness and they needed it, parts fit like a glove,..squared everything in lathe, clocked everything...bottomed pieces out on squared cuts,.tacked it up, finish welded it, no balancing and no vibes...like it should be, d-shaft still in my cousins k5 12+ yrs later
haha ya i took geometry. i've got a d60/14bolt and a 241 so im also buying an SYE kit. Im goin to be running the rancho 9000's 15 inch travel. and once its all completed i will probably add bump stops and limiting straps. So if i measure it at full compression and full droop the difference in those 2 measurments should be how much slip i need?
