Shake flashlites
I don't like the LED mag lights. It gives off a "fuzzy" light. I don't think they are as bright and they are hard to focus. But this was with a LED conversion kit. I never tried one that came with LEDs in it from the store.
Kind of a side note, but this is a real LED light. This one will blow you away. I purchased the T1 which is the predecessor to the TK10.
This has a high and low mode. I lit up my neighbors house that is 100 yards away on low mode. And the light is small enough to hide in your hand.
Store link
About The Fenix TK10 Tactical
Fenix™ TK10 Flashlight
The Fenix Tactical series (T) features a powerful, solid, durable, and waterproof design intended for rugged outdoor and military use. It’s as solid as a tank. The TK10 uses two CR123A batteries and maintains excellent constant brightness with two output modes: General mode, which can last for a whole night and can be used for general illumination, and Turbo mode, which can be used whenever high-powered light is needed – search and rescue, long-range target identification, etc.
Features
• Cree Premium (Q5) 7090 XR-E LED with lifespan of 50,000 hours
• Two modes of output, selected by turning the bezel:
¨ Turbo Mode: Constant 225 Lumens, 1.5 hours
¨ General Mode: Constant 60 Lumens, 10 hours
• Highly efficient focusing head - throws beam over 200 meters
• Textured Reflector for optimum balance and transition between spot and flood
• Digitally regulated output - maintains constant brightness
• Low battery indication system
• Uses two 3V CR123A lithium batteries (included)
• Durable aircraft-grade aluminum housing
• 135mm (length) x 34mm (diameter)
• 136 gram weight (excluding batteries)
• Premium Type III hard-anodized anti-abrasive finish
• Waterproof to IPX-8 Standard
• Tactical grip ring for Cigar technique (removable)
• Toughened ultra-clear glass lens with anti-reflective coating
• Tactical tailcap switch with momentary-on function
• Tactical body clip – attaches securely for easy carrying
• Anti-roll, slip-resistant body design
• Included accessories: holster, lanyard, two spare o-rings, spare rubber switch boot, allen wrench, two spare screws, and copper spacer ring.
shaking
i think my blazer would keep one of the shake lights "shaked up" pretty good all the time : , )
I hated the shake light I had. Since then I have bought a bunch of the cheap small led lights. They usualy have a display of them next to the register at the auto parts store. About the size of a roll of quarters maybe a bit bigger, inside it runs off 3 AAA batteries. cheap and bright I keep them all over the place. They seam to last for a VERY long time as well.
pics.
$3 9 LED's 3 AAA's
bigger about $12-$15 6 LED's 1 xenon bulb 3 C batt's 3 modes 3 led 6 led or xenon
Cheap lights for the win!
stinger is by far the best, imo
