Shave your 14?
mason72
Registered Member
tucson az
Did anyone reuse the magnet from the bottom of the diff after shaving the recessed pocket off that the magnet sat in?
Not the best pic, but cut 1/2 way thru the bolt hole...never saw a magnet in mine, its from 1975 go figure, mine is pretty beat, both spindles have speedy sleeves on the seal surface, used a thread file to clean up the spindle threads to even get the axle nuts on and the hubs and have a couple helicoils for the axle bolts. I didnt mind grinding on this axle.
