RoccoK5
I'm considering my options for extending the front shock mounts. I'll be running a 4" spring with a zero rate, and the goal is to run a 12-14" travel shock. I'd also like to maintain the same geometry/shock angle as stock, or better, move the mounts forward on the frame to get the shocks more vertical. However, the way the frame is formed for the stock mount gets in the way and limits my options. Removing the riveted bracket is easy enough; the bulge and dimple in the frame is what I am referring to -- this gets in the way of placing my new mount in a more vertical position:
I've seen some creative ways around this (https://ck5.com/forums/threads/ford-towers.313713/page-3#post-3401147), but curious if anyone has modified the frame in this area to effectively remove/shave the stock mount? I'm thinking of doing this by cutting out this section of frame and welding in a piece of 3/16" flat stock to give me a flat mounting surface for some new extended mounts (either the Ford towers or something similar). Basically cut out this area:
And patch in a flat section, so I'm left with a flat frame:
Regardless of the mounts I end up using (Ford towers, stock front quad shock, fab my own, etc), I think this will make whatever I end up doing easier and cleaner in the long run. My K5 is currently torn down to the frame, so this should be pretty easy to do. Any thoughts on this approach, or other ideas I should consider?
I'll probably end up cutting and filling the frame to remove the stock shock mount, getting the frame coated, and then waiting until after I get the body back on and some assembly done in order to mock up and mount some bolt-on shock towers. Either that, or paint the frame instead so I can more easily grind/weld/repaint down the line?
