k20
3/4 ton status
Well, installed my rebuilt IP today (it was jammed up according to the injection shop), anyway, fired it up and at idle it is about 40psi of oil pressure. What are yall looking like at cold idle, just wanting to get an idea of how tired my engine is. Next, I have some smoke at idle. I know one of my injector lines is dripping and that bank seems to smoke just a tick more than the other, might be getting a little air. At idle the smoke seems to be a light gray/light blue (truck is in the shade, damn time change). If you barely rev it up, the smoke takes on a slightly whiter shade, but if you stab it really quick it almost looks brown. My pump appears to be slightly advanced (didnt notice it til I had it running, must have moved slightly when I was tightening it up), it looks advanced by about a line width.
Should I advance or retard it to try to clear up the smoke at idle, or would that be considered normal? As it sits, it will haze up the yard when it runs for more than about 10 mins.
