Ok, I just rebuilt the dist. on my '74 K5 (new cap, rotor, points) and when we initially put it back in, pointing to number 1 at tdc, after priming the new carb, she lit right off. It would idle great, sounded good. The problem was whenever you gave it gas it would would backfire through the carb if you tried "rompin" it. If you gave it gas slowly, it would rev a little bit but the end result would be the same. Eventually we had a cool fireball come out the carb. We tried retarding the timing, but to no avail, same thing. We eventually ran out of time, and had to call it a night. Came back a week later and started all over at step 1. This time we couldn't even get it to start except every once in awhile and it was only briefly, sounded like it was starving for gas. Also, I should note that replacing the intake and carb were the intial project and decided to do the dist while we were there. Considering going to HEI, but not sure that will solve my problem. Help please?
Thanks.
Thanks.
