I have welded flux core forever. I upgraded to a Hobart handler 180 to run on gas. It was a well used unit and had a few issues. I just ran some gas through it and if the weld looked ok it was good enough for me. I just got a nice Hobart Ironman 230 mig and will be running on Argon co2. I am searching for flow rates. I used to just use a regulator and let it rip. I figured I was probably using too much gas so I bought a regulator with a flow meter. I am wondering what the flow rate should be and do I need different flow rates for different amperage welds?
Same question for my Lincoln TIG on 100% Argon.
