I don't know what "detents" are. What are they?
There is a plate inside column with groves in it for each "gear". Is that what ur talking about? Otherwise the bushing at the end of the column or the ones Scott is talking about can give you a lot of play. Sounds like the linkages are tight though....
That's the part that I suspect is bad on my column. I know for a fact the trans setup is tight, the white bushing and spring are in place and intact, but my shift feels sloppy at the column. All of this was worked with last year when I rebuilt the trans.Like I said, I don't know what detents are. The only thing I'm talking about is this thing which only acts at a shift lever stopper between gears. I second the 350 to 700 column working as my column came off Vee's truck, which I believe came with a th350.
