91 k5 350 700r4 tranny 4x4 with suspension lift and body lift.
I’m I dumb and missing something obvious? Start off I’m not getting to select lower gears then drive. So I can select p,r,n,d but nothing lower. I loosened the linkage adjustment to the rod, pulled up the column shifter to park position (top as far as it would go) tighten bolt down on linkage but still only go in drive at the very bottom shifting down the column. What am I missing to select 1,2? Bought it this way… plenty of room on the rod either way adjusting.
